Fs lever
Okami 359
(@okami-359)
Fs lever
Just got my mmu2s kit and started on the.mk3s upgrade. After disassembly I started on the rebuild but can't find the fslever piece. Can anyone tell me which bag it is supposed to be in? I didn't see it listed on any of the bag labels.
Opublikowany : 20/04/2019 11:54 pm
Re: Fs lever
Hi Randy,
I don't believe the MMU2S upgrade has a FS Lever as such, instead the idler door has an extended arm which actuates a relocated filament sensor
see Step 11 in the guides at https://manual.prusa3d.com/Guide/3B.+MK3S-MK2.5S+-+extruder+upgrade/1070?lang=en
I am still waiting for my MMU2S upgrade to arrive
Opublikowany : 21/04/2019 1:10 am
Re: Fs lever
You appear to be using the wrong assembly guide.... I believe my previous post points to the correct assembly guide for MMU2S
this image is from the Mk3 to Mk3s upgrade, which contains different parts
Opublikowany : 21/04/2019 1:18 am
Okami 359
(@okami-359)
Re: Fs lever
Thank you for the help!
Opublikowany : 21/04/2019 1:24 am
