First Multi Prints
Flack
(@flack)
First Multi Prints
First multi 4 color print using PLA, I used my pla from my old printer. I just used the generic PLA from the slicr3 menu, but just changed it to my good known printing temp. Everything else was just left as profile setting.
I had one filament jam on number 4 color, but this was due to the tension on the MMU2 needed tightening more on number four side than the other and that fixed that one jam.
20 hours 10 mins to print.
I also forgot that I changed the setting to wipe in to the model as you can see in the infil the different colors.
I also forgot that I changed the setting to wipe in to the model as you can see in the infill the different colors.
Also did the lizard that came out good.
Opublikowany : 15/12/2018 1:58 pm
