Filament unload from LCD only moves filament a little
AgentNoise
(@agentnoise)
When using the Load to nozzle I can get filament to extrude most of the time now(yay?!).  However when I try to unload the filament it only unloads a tiny bit and then stops. The LCD screen goes back to the Info screen as if it thinks it was done unloading.  I have to send the unload command many times before it will unload. Each time it moves just a tiny but until eventually it moves real fast and unload the filament. The FINDA sensor does show as active when filament is loaded.
Postato : 11/07/2019 1:18 am
