Filament Connection Problem Inside Buffer Assembly For MMU2S.
How do you run the filament thru the buffer for the five the entry tubes to the exit tubes? The filament keeps running off course inside the buffer assembly even after I tried straightening the filament. Print operators should not have to fiddle around trying to get filament to connect to the tubing.
This topic was modified 6 years temu by 3D Dave
Opublikowany : 23/09/2020 4:17 pm
RE: Filament Connection Problem Inside Buffer Assembly For MMU2S.
This might help:
Opublikowany : 29/09/2020 5:41 pm
