Extruder not moving after after validating 9 points on build surface.
After assembly and installation of the MMU2S, I went to perform a first layer calibration. The printer validates the 9 points on the build surface, moves to the home position and stops. The filament is loaded and passes into the extruder with the extruder staying in the home position. I only had one material loaded, but otherwise nothing else of note stands out.
Este debate ha sido modificado el hace 7 years por IPrintStuff
Respondido : 28/11/2019 10:51 pm
