Can the selector be calibrated?
this year I finally found the time to upgrade my original MK3 to MK3S+MMU2S. This was a lot of fun and I learned a lot - including not to handle the blade 🙂
but right now, after installing everything, I am stuck - this is the C1-Version of parts. I try to input filament, but as soon as it should reach the selector it can not go forward. Is there any way to calibrate the selector? I fear that it is slightly misaligned, because when I tyke the selector out, try some filament from the PETG-tube to the MMU2S-Unit (without the selector), it works fine and filament through the selector itself works fine too, but both together doens't work...
best regards, Hanno
Napsal : 02/01/2021 4:32 pm
