Atomic PLA and MMU2 settings?
Joe
 Joe
(@joe-16)
Has anyone had success with atomic PLA and MMU2? I’m having a heck of a time getting success. My tips are either too stringy or too big, both causing causing jams. I’ve tried a wide variety of temps and ramming settings.
Publié : 23/10/2018 7:21 pm
m00dawg
(@m00dawg)
RE: Atomic PLA and MMU2 settings?
I am using Atomic with the MMU2s and, for the most part, it works well. I use stock ramming and 210C. I have found the shiny filaments seem to create a bigger tip which can cause the MMU to struggle. This happens with normal Atomic filament for me too just far less often. I think it may require slight ramming adjustments but I haven't dove into that just yet.
My MMU2 came as an 's' already so I can't compare to the normal MMU2 but for the most part it is running very well - now flawless, however, but I haven't had any skipped layers or anything. Mostly just unloading a beefier tip or sometimes the filament backs out of the MMU a bit too far and I have to nudge it back in. I typically do the latter about once per MMU print.
Publié : 25/04/2019 2:16 pm
