After MMU setup and successful firmware flash, still seeing MMU N/A
[Resuelto] After MMU setup and successful firmware flash, still seeing MMU N/A
raphael.l3
(@raphael-l3)
Printer: Mk3S (upgraded from mk3 during MMU installation)
MMU: MMU2S
Printer firmware: prusa3d_fw_MK3S_3_7_2_2363.hex
MMU Firmware: prusa3d_fw_MMU2board_1_0_5.hex
I completed the MMU setup this afternoon and successfully flashed the printer, but under the Support menu on the LCD screen I still see MMU: N/A. The MMU has one green LED lit; the printer LCD displays MK3S on the info page. I've tried re-seating the MMU data cable but it hasn't helped. Any ideas?
Respondido : 30/06/2019 12:35 am
raphael.l3
(@raphael-l3)
RE: After MMU setup and successful firmware flash, still seeing MMU N/A
Sorry, while doing a continuity check I reseated the data cable again and it worked. looks like user error!
Respondido : 30/06/2019 12:46 am
vitor.j
(@vitor-j)
Thanks for the tip. Same thing happened to me. The 2 data cables were not properly seated in the rambo box.
I took the board out of the box to check and properly connected them. I could not fully  see them while inside the box.
Respondido : 10/12/2019 11:16 pm
