After filament switch it takes some time for it to come out of nozzle
Knedl
(@knedl)
Hello,
I tried printing two colour object, both filaments are PLA. At the start when it loads filament it works ok, but after it switches filament and starts printing, nothing comes out for like 30 seconds, but it keeps printing, so it skips some layers. What causes this problem?
Opublikowany : 09/09/2022 4:39 pm
RE: After filament switch it takes some time for it to come out of nozzle
Are they different brands with different print temperatures?
Opublikowany : 11/09/2022 1:09 pm
Knedl
(@knedl)
No they are both the same brand, same material. If I switch materials it is also the same, when it switches them it comes out of nozzle with delay. But at the start it works perfectly fine.
Opublikowany : 13/09/2022 1:44 pm
Twobit
(@twobit)
Im having the same issue. doesn't matter what filament I'm using. Its not extruding enough before it starts to wipe... It will finish the purge wipe and tower before it even starts to come out of the nozzle.   Using the default setting and purge volumes.
Opublikowany : 29/10/2022 8:44 pm
towlerg
(@towlerg)
Are you able to monitor nozzle temp during and after filament change?
Opublikowany : 30/10/2022 3:11 pm
Twobit
(@twobit)
nozzle is staying at temp. just not extruding enough.
Opublikowany : 30/10/2022 3:54 pm
