Worn surface on heated bed exposing copper traces -- how to insulate?
The insulating coating on my heated bed has worn a bit at the rear and the copper traces are increasingly exposed. I want to insulate them, but don't want to introduce a bulge in the spring steel sheet when it's applied. My 1st instinct is to apply a strip of tape, but I recall reading that some sort of lacquer is very effective without adding significant height. Any tips appreciated!
Respondido : 12/11/2019 4:07 pm
RE: Worn surface on heated bed exposing copper traces -- how to insulate?
I was going to suggest a lacquer.  For a small spot then something as simple as nail varnish would work but for a larger area and to keep the bed even then you can get spray on lacquers.  Would need to check the max temps of which ever one you go for naturally and I'd remove the bed for the application unless you do a good job masking off the rest of the printer.  Would ruin your rods if some got one there.
There are loads available and all should insulate the traces.
Respondido : 12/11/2019 4:21 pm
Nikolai
(@nikolai)
I would use something like that: https://www.amazon.com/Scratch-Remover-Painting-Chevrolet-Hyundai/dp/B07GVMB5LD/ref=sr_1_25?keywords=auto+metal+paint+repair&qid=1573579069&sr=8-25
If you will get a small bulge, go with fine sandpaper.
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Respondido : 12/11/2019 5:23 pm
The coating is generally an epoxy barrier, aka solder resist.  You can buy it in small amounts for home use.  It is usually applied via silk screen. And you can do the same.  Some is UV cured.
ps: a high temp engine paint might work, flat black or even hot rod silver. lol.
https://www.globalindustrial.com/p/janitorial-maintenance/paint/aerosol/vht-extreme-high-temperature-coating-clear-satin-finish-11-oz-aerosol?infoParam.campaignId=T9F&gclid=EAIaIQobChMIt8SV-6bl5QIVxRd9Ch2BjwpQEAQYAyABEgLM-fD_BwE
Esta publicación ha sido modificada el hace 6 years 2 veces por --
Respondido : 12/11/2019 6:25 pm
PPRRUUSSAA
(@pprruussaa)
What do you think about Kaptonband? - Carsten
Esta publicación ha sido modificada el hace 6 years por PPRRUUSSAA
Respondido : 12/11/2019 7:29 pm
Peter in Katy
(@peter-in-katy)
I would start with a small strip of kapton tape.  According to Google, the 2.7 mil thickness is just under 70 microns.  Maybe a small nylock adjustment would compensate, or even the 7x7 grid.
Do let me know, as I've got about a 1.5mm wedge where I see copper.  😀
Nothing major just yet, but...
Respondido : 12/11/2019 10:05 pm
rmm200
(@rmm200)
If I may ask - how did you wear the surface of your heated bed?
I put the steel print sheet against the pins and lower it. There is never any sliding on the bed.
I was sort of expecting the heated bed to last until the heater elements burned out...
Respondido : 12/11/2019 10:12 pm
Posted by: @robert-rmm200
Probably using some sheets that aren't coated at the ends. I've put blue painter's tape over those. I probably let it slide a bit as I lift the sheet more than anything, partly due to the low table I had it on for the 1st 18 months.
Respondido : 13/11/2019 2:38 am
I was wondering if deburring sheets was a good idea, and it seems you've proven it is.
Respondido : 13/11/2019 3:23 am
Posted by: @tim-m30
No doubt. I deburred some of the sheets, but likely missed a couple. After I patch it up, I'll sit down and run through them all.
Respondido : 13/11/2019 3:33 am
rmm200
(@rmm200)
It looks like a slightly cheaper product good to 650C might be:
http://www.deco-color.com/products_en/high_temperature.html
Respondido : 13/11/2019 4:59 am
Nice! I need to find a nice Prusa orange. Thanks everyone!
Respondido : 13/11/2019 1:03 pm
Boulder
(@boulder)
V6
Respondido : 15/11/2019 1:13 pm
