Wizard Calibration with Bear X axis Upgrade
So I just finished assembling the Bear upgrade on one of my mk3s's and just curious if a Wizard Calibration can be performed after the firmware was flashed back Prusa 3.8.1.
Postato : 29/04/2020 6:15 am
RE: Wizard Calibration with Bear X axis Upgrade
I am in the same boat as you, followed the steps of calibrating with the bear calibration firmware and flashed it back to Prusa’s firmware. I don’t know if running a full Prusa calibration will make it fail and wind up having to reflash with bear and start over. Have you figured anything out yet?
Postato : 30/03/2023 2:52 am
Yes, if you are using Bear Exxa you will have to do your recalibration using the Bear firmware.
Postato : 30/03/2023 9:50 am
