[Gelöst] Usage of Raspberry Pi Zero W and Raspberry 4 simultaneously
Elmar
(@elmar)
After posting this question by error into a false section of this forum I hopefully will be now in the correct section. 😊
Is the Raspberry Pi Zero W for using WLAN and the Raspberry 4 for touch display compatible for simultaneously usage at the MK3s ? The Zero W will be connected directly to the Einsy Board and the Pi 4 to USB, right? But do PrusaPrint and OctoScreen Plugin interfere or does it work?
Veröffentlicht : 08/07/2020 9:00 pm
Elmar
(@elmar)
RE: Usage of Raspberry Pi Zero W and Raspberry 4 simultaneously
Found out that the 4 can all the zero W does only better, so there is no need to use them together. So question is solved.
Veröffentlicht : 09/07/2020 5:47 am
