Upgrading a P3Steel !
meobeo.u
(@meobeo-u)
Hi, I have a P3Steel (30x30x30cm printing area) that I would like to upgrade with the Prusa kit - mostly because I want the autoleveling / autocalibration system. Will this be possible? And how do I find out which upgrade kit I should buy?
Lee!
Opublikowany : 15/01/2019 9:00 am
Martin_au
(@martin_au)
Re: Upgrading a P3Steel !
Given the P3 Steel is not an original Prusa, there is little certainty that any parts from an upgraded kit will work.
And given that you have a 300x300 bed, and Prusas use a bed of 25x21cm, then it's very unlikely that you'll be able to adapt the Prusa levelling and calibration system to your printer.
Opublikowany : 17/01/2019 1:42 am
I would recommend you just buy a full prusa printer.
Opublikowany : 17/01/2019 5:30 am
