Re: Thekkiinngg textured sheet v4 = AMAZING
I doubt anyone has an intact V1, my PEI came off in like the second or third print. He did me right though and I got to keep the sheet, so I have nothing but good things to say about the transaction, but it's smooth PEI now and I still use it regularly.
This is the only thing I can think of that was printed with it that I still have, I used PETG to print my support structure for the MK3 when I removed the power pack when making the IKEA enclosure. This was on the second side, was hoping the PETG would take off most of the material, you can see where some came off in the pic.
I figure it would be a rare find. I still hope someone has photos.
Had a little problem getting the bed to level using 7x7 if you put the sheet in the holes drilled out for the Prusa MK3, problem was top left corner where heatbed cable is attached, the plastic box protecting the heatbed cable touches the sheet and raises it slighly, however no big deal just put the sheet in front of the holes as bed is magnetized, and all is fine, pictures below.
No sure I understand why you have the sheet on backwards. My levels fine. Even the defects level fine.
The holes are not for the pegs
Is that what he thought? No wonder he had trouble leveling.
Thanks guys makes me feel even more stupid now................ 😀 😀 😀
Its just part of the learning curve
I think we all make mistakes.
Amen to that and so much to learn, thankfully some top people on the forum........... 😉 😉 😉
I have 3 of the textured sheets and have had great results with PLA and PETG. Have not tried ABS or nylon yet.
