Testing Print Surfaces
Strona 3 / 4
Re: Testing Print Surfaces
My wife is understanding but she puts her foot down on them coming on vacation with us. There are somethings I cannot talker into.
Besides, can you imagine that discussion with TSA? It’s a 3D printer. Sure sir, put you hands up and spread em. Your are gettin a cavity search. I might be the highlight of the trip.
Opublikowany : 04/01/2019 7:43 pm
Mustrum Ridcully
(@mustrum-ridcully-2)
I understand It is a SWMBO conflict... you are not alone 😀
Opublikowany : 04/01/2019 11:35 pm
Robin
(@robin-4)
Just been using one of these build sheets from FYSETC. Things really stick to it even without cleaning the surface.
Opublikowany : 05/01/2019 2:52 am
Here is my review of that surface.
Opublikowany : 05/01/2019 5:06 pm
[...] Here is my review of that surface.
Link?
Opublikowany : 05/01/2019 6:13 pm
I tried to post the link. Here is another attempt - https://shop.prusa3d.com/forum/general-discussion-announcements-and-releases-f61/review-cheap-mk52-print-surface-t26801.html#p122116
Opublikowany : 06/01/2019 4:54 am
Bunny Science
(@bunny-science)
5/5 stars for my 3rd party, Thekkiinngg textured PEI plate for printing PETG. It's been giving me more reliable adhesion and easier parts removal than the stock Prusa flat PEI plate. However, if you try it straight out of the package, you'll wonder why you bought it because nothing sticks.
You must initially condition the surface to bring out its good adhesion behavior. Wash with Dawn then do three cycles of Windex and IPA cleaning with your bed at printing temp to condition the surface. Finish with IPA, you do NOT need Windex residue to ease parts removal. Once conditioning is completed, adjust your live-Z. It will probably be 0.100 to 0.200 lower than for the smooth PRUSA sheet.
Textured finish looks great, but is slightly more sparse than the (impossible to get) Prusa textured sheet.
This has become the sheet I use for 95%+ of my prints. Nearly all my prints are in PETG. PLA also works on the sheet, but adhesion is not quite as firm as with PETG.
I only wipe the sheet down with IPA after 3/4 print jobs. Most of the time, I can remove the parts and not wipe down the plate if I only touched the plate with my fingernails (less oil transfer).
PETG behavior is reliable and consistent. I simply don't have to worry about my PETG 1st layers sticking correctly nor tall, thin objects toppling over. Parts come off so easily I can have ask wife to clear the plate when I'm away.
Thekkiinngg Prusa i3 MK3 Mk2.5 Double-Sided Pei Textured Powder-Coated Spring Steel Sheet V3 Version 3
Currently its about $64 with shipping from Amazon.
https://www.amazon.com/Thekkiinngg-Double-Sided-Textured-Powder-Coated-Version/dp/B07HQZCWDV/ref=sr_1_3?ie=UTF8&qid=1546795667&sr=8-3&keywords=thekkiinngg+prusa+i3+mk3
Opublikowany : 06/01/2019 6:33 pm
Found it cheaper on eBay
Opublikowany : 07/01/2019 12:07 am
KnightKap
(@knightkap)
RE: Testing Print Surfaces
Why Dawn specifically?  Does it matter?
I have this sheet (V4) and it made a few good prints, but now is refusing to hold anything. Got through two of the Save Pangolins with no trouble.  Tried printing the LFS elephant like 10 times now and always loses a piece along the way.  Freaking maddening.
Opublikowany : 28/05/2019 1:41 am
toaf
 toaf
(@toaf)
think dawn is good because it doesn't have the fancy stuff...safe enough for the wildlife...safe enough for my sheet.
Opublikowany : 28/05/2019 1:48 am
Posted by: william.b45
Lost pieces of the print or the Print bed surface?
I have found that PETG can stick too much especially if you let bed cool too much.
Opublikowany : 28/05/2019 2:02 am
KnightKap
(@knightkap)
Using PLA. Some of the pieces curling off the sheet and then causing a collision with the nozzle.
Opublikowany : 28/05/2019 2:11 am
Soap and plenty of water to rinse is all you need.  I do use IPA also.
Opublikowany : 28/05/2019 3:32 am
1 ludzie polubili
The magic is original formula Dawn without vinegar, hand softeners or other fancy additives. Other brands will work, of course, and Dawn itself is sold by other names (e.g. Fairy in UK), but Dawn is something that can be recommended and is widely available. If your can't find it, try something similar (no additives, etc.) that you can.
Your loose parts can be caused or aggravated by two factors that need to work together well for successful prints. The fix is easy if you had a printer and PEI sheet that was working, but degraded over time. Here's mama's tried and true copypasta recipe to get you going...
You are having bed adhesion issues. PLA should lay down cleanly on the PEI print surface and hold throughout the print. There are 2 main causes of bed adhesion issues. Even if you're dubious that these are the cause of your problems, they're 2 fundamental troubleshooting steps you need to complete to rule out the basics:
  • A dirty PEI print surface. Even if you don't think this is the cause, it's always a good idea to make sure your PEI surface is clean before trying any other fixes. Take it to the kitchen sink and give it a good dunk with Dawn (original formula, no vinegar or hand softener variants) dishwashing soap or your local equivalent (e.g. Fairy in UK). Use a clean paper towel to clean it off, and another to dry it. Avoid using any sponge or cloth that has been in contact with grease. Above all else, avoid touching the PEI print surface. Once it's good and clean, you should be able to use 91%+ isopropyl alcohol between prints, 100% acetone when that fails, and another dunk when acetone fails. Worst-case, use a 3M 7445 ScotchBrite pad or equivalent to give it a very light buff, but only infrequently.
  • If you have not already done so, try using Jeff Jordan's "Life Adjust" procedure for calibrating your Live-Z setting. It is much easier to use and understand than the on-board routine. In general, start high (less negative) and work lower (more negative) in large increments (e.g. 0.1mm) until the filament starts to stick on its own. When it's right, you should be able to gently rub it without it coming loose. Then start lowering (more negative) the level until there are no gaps between layers. When you've got your Live-Z setting adjusted properly, you should be able to gently rub the extruded lines without dislodging them.
And above all else, avoid touching the PEI print surface.
Try those 2 steps. If you're uncertain of the Live-Z results, post pics here of the 75x75 print bottom and you'll get quick help.
In the future, a good dunk with Dawn will restore both sides of your to like-new condition and is always a good thing to try when you encounter 1st layer problems.
If you want more detail, I've consolidated my notes on Prusa PEI adhesion, bed cleaning, and Live-Z calibration. I've done a brain dump on nozzle sizes as well.
Opublikowany : 28/05/2019 3:59 am
1 ludzie polubili
KnightKap
(@knightkap)
Thanks.  Washed the plate quite thoroughly with dish soap.  I don't have dawn, but our soap is an ammonia free, no additive option as well.
Followed with a strong dose of IPA.
Printed the 75x75 square which adhered and looked decent (to my rookie eye).
Then printed the LFS elephant and it finished with no issues.
This post was modified 7 years temu 2 times by KnightKap
Opublikowany : 28/05/2019 8:44 pm
xavierx
(@xavierx)
This thread has great information! Thanks for sharing!
My experience is that the Prusa PEI sheet is too adhesive for PETG printing (I do mostly PETG) and the surface is damaged over time
The Prusa powder coat is never in stock so I have given up trying to buy one
The ebay powder coat (same as the OP) works perfectly for me with PETG. Parts are much easier to remove than the Prusa PEI sheet and I have done loads of prints and the surface is is good condition, better than expected for a Chinese ebay purchase
Opublikowany : 28/05/2019 11:08 pm
Posted by: xavierx
[...] The Prusa powder coat is never in stock so I have given up trying to buy one
They were available for several hours today, and at least briefly for each of the last few days. You just have to check a few times daily.
Opublikowany : 29/05/2019 12:36 am
I ordered last week.  Still waitlisted.
Opublikowany : 29/05/2019 1:08 am
Posted by: charles.h13
There's a waitlist, or are you still waiting one from a 2018 order? I think it's just hit-or-miss for e-store stock.
Opublikowany : 29/05/2019 1:44 am
Posted by: bobstro
I should clarify.  My order for bed sheet from last week is waitlisted.
Opublikowany : 29/05/2019 2:30 am
Strona 3 / 4
