STEP File for Prusa Printable Spool Holder?
NineBreaker
(@ninebreaker)
I'm currently setting up a farm of MK3S+ printers and am looking to a custom spool holder for mounting spools that are low profile as I am trying to compact the printers onto a shelf I have set up. I'm not printing very high for these parts so I wanted to modify the existing printable spool holder to hang horizontally over the back of the printer and add a slot for a small piece of PTFE to guide the filament through. However, I've tried looking for it but was not able to find the STEP file for it, only the .stl. Anyone know where I could find it?
Opublikowany : 02/11/2022 11:24 am
Most farms dispense with the frame mounted spool holder and fit holders to the racking, sometimes with a filament guide to aid the pathway.
There are alternative spool holders all over printables.
Opublikowany : 02/11/2022 8:59 pm
Netpackrat
(@netpackrat)
RE: STEP File for Prusa Printable Spool Holder?
Last week I set up a reverse bowden feed for my Bear with a side mounted spool holder, it seems to work pretty well.  Only thing I think I am going to change is to make some plain bushings and substitute them for the ball bearings, since the spool almost moves too freely.
https://www.printables.com/@Netpackrat/models
Opublikowany : 14/11/2022 5:03 am
