Spool Holder Modification
Ronald Tibbetts
(@ronald-tibbetts)
No offense to the MK3 printer however, I didn't like the herkie jerky movement of the filament spool while printing.
I constructed a spool holder with rollers supported on ball bearings. The filament now feeds smoothly off the spool.
I know, just have too much time on my hands
Napsal : 18/09/2020 1:06 pm
2 lidem se líbí
Flying printer
(@flying-printer)
RE: Spool Holder Modification
That looks really we designed. Anything that keeps the filament flowing smoothly from the spool to the extruder is good.
Napsal : 18/09/2020 10:47 pm
KevinK
(@kevink)
Nice job - I had done something similar for my pegboard based spools.  But I discovered that the bearings actually made my spools spin too easily and led to excess filament being run off if the carriage moved quickly and tugged the filament.  So I actually went back to non bearing holders.  Just an observation you may want to consider adding some adjustable drag to the spool if those bearings are really smooth.
Napsal : 18/09/2020 10:55 pm
Ronald Tibbetts
(@ronald-tibbetts)
Kevin
My first attempt was using the spool center hole. I then realized that the center holes in the spools vary in diameter so I would have to make several inserts so I changed to my current design. Actually the first one ran too smooth and the filament would overrun.
The current one works great.
Napsal : 19/09/2020 12:12 am
can you post a build thread?
Napsal : 19/09/2020 1:46 am
1 lidem se líbí
Ronald Tibbetts
(@ronald-tibbetts)
Charles,
If I can figure out how to do that....... 🙄
Napsal : 19/09/2020 2:33 pm
@rtibbetts
Just post the list of parts and files you used to print it.
Napsal : 19/09/2020 6:24 pm
Peter M
(@peter-m)
https://www.prusaprinters.org/prints/6174-repwinder-v214
Has a rewind.
Napsal : 19/09/2020 10:19 pm
