spool holder for bigger filament spool
oter11
(@oter11)
hi,does enyone have recommendation for a new spool holder that kan take 2-3kilo spools?it need to be mount same as it is from prusa,dont have place for it another place.
adjustable width,and use 608 bearings
and fit mk3s+
Postato : 29/07/2021 12:04 pm
Eric E
(@eric-e)
Utenti
Bigger spool
i don’t have an answer for you, but I heard that the extruded doesn’t have enough muscle to turn bigger spools.
No reason to believe that is true, but I will follow this as I have the same interest. I’m looking at as big as 10# spools. I will be mounting on a 2020 framed enclosure.
Don’t trust forum advice.
Postato : 29/07/2021 4:36 pm
Weight and friction
It's a question of friction. Definitely look at a spool holder with bearings. I'd get that weight off the top of the frame in any case.
Postato : 29/07/2021 5:25 pm
oter11
(@oter11)
re
Posted by: @bobstro
orginal spool holder is for 2 spools,thats about 2,1 kilo,so i think it will not be a problem with a 2,3 kilo spool
Postato : 29/07/2021 9:07 pm
Friction
Posted by: @oter11
More weight on one side with no bearing is likely to increase friction, but do what you want.
Postato : 29/07/2021 9:45 pm
oter11
(@oter11)
re
Posted by: @bobstro
Posted by: @oter11
thats why i ask if someone know of a spool holder with bearings and adjustible width,so it can fit one spool
Postato : 29/07/2021 9:50 pm
I use this one, works for me:
https://www.prusaprinters.org/prints/469-spool-holder-2kg
Postato : 29/07/2021 11:29 pm
Xanthe
(@xanthe)
See this: by @karl-herbert
https://forum.prusa3d.com/forum/postid/485938/
It looks like a very good design, I'm printing one now.
Postato : 15/08/2021 5:04 pm
