Source for double bearing idlers
jgalak
(@jgalak)
I'd like to upgrade my Y idler (and maybe the X, later) to a toothed, double-bearing idler (in conjunction with a tensioner). Probably 20 teeth, to reduce stress on the belt.
Anyone have a specific source? The ones on Amazon don't have great reviews.
Thanks.
Postato : 21/07/2018 4:18 pm
Re: Source for double bearing idlers
I got these
https://www.ebay.co.uk/itm/5pcs-Idler-Bearing-GT2-Timing-Pulley-16-20T-3-5mm-Bore-6mm-Belt-3D-Reprap-CNC-/322543747663?var=&hash=item4b191b024f
i have fitted them to the Y axis on my mk3 and Mk2 MMUv1
working fine
will fit the others when I dismantle the X axis next
Postato : 21/07/2018 4:42 pm
jgalak
(@jgalak)
Thanks, Joan, but I should have specified - I am looking for a US source. The seller in that link doesn't ship to the US 🙁
Postato : 21/07/2018 6:05 pm
JLTX
 JLTX
(@jltx)
print your own. works awesome. https://www.thingiverse.com/thing:2763870
Postato : 22/07/2018 6:11 am
richard.l
(@richard-l)
Utenti Moderator
Amazon has these. I can't vouch for how well they work.
https://www.amazon.com/dp/B078S5LCXD/ref=biss_dp_t_asn
Postato : 23/07/2018 4:27 pm
berthold.h
(@berthold-h)
I got these
working fine
Do you feel this is a necessary/beneficial upgrade for the MK3?
Thanks
Berthold
Postato : 30/07/2018 4:26 pm
Hi Berthold
I think that the smooth rollers pressing onthe teeth of the belt. Distort the teeth leading to loose belts and possible vibration
And the twin bearings offer more even support for the belt
One of my y belt idler bearings collapsed and lead to a number of worsening prints as the issue developed. Thenit finally collapsed and took the printer out of service
I now usually have at least one spare in my drawers
I currently have two spares for upgrading my X Idlers and one spare. Unallocated
However i need to build my other printer and that needs two idkers so i probably need to buy more in the near future
Regards Joan
Postato : 30/07/2018 5:23 pm
berthold.h
(@berthold-h)
Hi Joan,
What size idler would be the correct one. I saw your ebay link and they give several options.
I guess it would be 20T and ID 3mm. Correct?
There are some on Amazon
https://www.amazon.es/Rueda-sincrónica-20-dientes-aluminio-impresora-BIQU/dp/B06X3QCHW6/ref=nav_ya_signin?_encoding=UTF8&pd_rd_i=B06VSL9W9L&pd_rd_r=6c7ae3ff-9444-11e8-b123-9b8a07b4d4b1&pd_rd_w=8qemn&pd_rd_wg=8CKPL&pf_rd_i=desktop-dp-sims&pf_rd_m=A1AT7YVPFBWXBL&pf_rd_p=2421800510383999403&pf_rd_r=SPVBE2145ERB49BE42AJ&pf_rd_s=desktop-dp-sims&pf_rd_t=40701&refRID=SPVBE2145ERB49BE42AJ&th=1
regards
Berthold
Postato : 31/07/2018 12:01 am
They look Ok Berthold
The right one is original prusa
Regards Joan
Postato : 31/07/2018 12:28 am
berthold.h
(@berthold-h)
Thanks Joan!
I appreciate your help and your advice given here so generously!
Kind regards
Postato : 01/08/2018 3:52 pm
My pleasure Berthold.
others helped me, now it's my turn to help
Postato : 01/08/2018 4:26 pm
NewShockerGuy
(@newshockerguy)
RE: Source for double bearing idlers
Little bit of an older thread but wanted to comment since I just built my MK3S.  I have NO issues thus far.  But after researching it does make more sense to have a toothed idler since the motor bearing is toothed.
One question I can't seem to get a for sure answer on is would there be any different from getting a 16t idler or a 20t?  Wouldn't one want to get a 16t since the Y motor uses a 16t gear?  How would the belt even fit on a 20t?  I ask this only because it seems like 20t idlers are abundant but I can't see to find a good source for 16t?
This seems super easy to change so I'd rather do that than mess with the X axis at the moment until something wrong.
Thanks much,
-Nigel
Postato : 20/01/2021 8:36 pm
Hi Nigel,
the mk3s designed to use a 20 tooth idler, smooth or toothed,
using a smaller idler will cause reduced clearance behind the X axis carriage between the belt clamp and the belt, also the belt tension will change a little as the X carriage approaches the right hand side
Postato : 21/01/2021 1:45 am
