Some questions before I replace my power supply
nic
 nic
(@nic-3)
My power supply recently died on my MK3. After doing some searching and reading, I plan on replacing it with a Meanwell LRS 350.
I am always a little leery when dealing with electronics so I wanted to ask some questions before I jump in. I have put together a couple computers and bought the MK3 kit so I have some experience.
1. This power supply will work, correct?
https://www.amazon.com/MEAN-WELL-LRS-350-24-Printer-Industrial/dp/B07VRK86SP/ref=sr_1_2?crid=38YWZ4C3LCEVZ&dchild=1&keywords=meanwell%2B350%2B24v%2Bpower%2Bsupply&qid=1590635420&s=electronics&sprefix=meanwell%2B24%2Celectronics%2C198&sr=1-2&th=1
2. Can I reuse the power switch and plug from the old unit or should I get new ones?
3. Is there anything I should pay particular attention to when wiring things up? I don't want to fry my printer or burn my house down.
Any advice or wisdom is greatly appreciated.
Respondido : 28/05/2020 3:24 am
Miembro
RE: Some questions before I replace my power supply
I purchased the same one and paid a few bucks more.  It will work.
MEAN WELL LRS-350-24 DC Power Supply, 24V 14.6A 350W
I replaced my power supply cables at the same time and added quick connectors:
XT60 Connectors Female Male
I also replaced the case:
https://www.thingiverse.com/thing:3450424
This allows me to put my power supply on my table outside my enclosure.
Respondido : 28/05/2020 9:19 am
rmm200
(@rmm200)
Meanwell should be fine. I have the same one sitting, waiting for an excuse to add it in.
Thingiverse has some PSU ends you can print that add a socket and switch. You would need to buy the appropriate parts.
MK3 advantage - you can move the power fail board to the new PSU. Can't do that with the MK3S PSU.
Respondido : 28/05/2020 2:56 pm
