Raspberry Pi Zero + MK3s per manual
Christopher Laney
(@christopher-laney)
So I've read through the comments about the Zero and suggestions / warnings when connecting to the printer in the case and running PrusaPrint.  That said, I have mine setup, runs perfect, host the site perfect, even runs the PiCam beautifully.
Only thing I am running into is this:
  • Power, other users who do this; do you leave your printer on at all time?
    • If so, is there a way to power down the screen to prevent burn in, or is this not a concern?
    • If not, how does your Zero/Ocotprint handle powering down and back on?
Reason I ask is that I am 3 printers in at this point, and I tend to power down when not in use.  I've noticed that if I do not pull up Octopi and shut the site down, when I power on again the zero does not connect to my router (shows the registered static ip, but device is not connected.)  To resolve I have to pull the Zero from the case and connect to a monitor to type in a command (dont have said command readily available and I'm in a 3 hour print atm) at which point the Zero/OctoPi finishes starting up and works as expect, then I can run the shutdown command and place it back in the printer.
What is the suggested way to do this, leave it on, power it down, am I missing a config in the octopi to address improper shutdowns? Advise me Wise Prusa Masters
Thank you in advance for your time
PS, to be clear the printer I am running at the moment is a Kit built MK3S, Firmware is up to date, and I have run 1 update in PrusaPrint/Octopi since installing it bringing it to current release.
This topic was modified 6 years ago by Christopher Laney
Posted : 02/12/2019 10:32 pm
AXG68K
(@axg68k)
RE: Raspberry Pi Zero + MK3s per manual
You should power it down from the octoprint web site.  On the upper right hand corner there is a power button.
If you have the time you could make and awesome setup with a phone usb charger so when it detects that the power has been shut off it will issue a shutdown -now command.    Maybe a less awesome setup with just a button on top of the Pi.  I did the less awesome version of this on a Pi_1 scanner project, it worked out fine.
BTW, the pi zero really sucks.  Not only does the  web page respond like molasses, you will eventually get slow and jittery prints.  I ripped it right out when I experienced my first jittery print. The packaging is really sweet and neat but it is not powerful enough and needs multi cores to function as a web server and serial device at the same time.
Posted : 01/01/2020 11:54 pm
