Rasberry Pi 4
Wes
 Wes
(@wes-3)
Rasberry Pi 4
I have spent hours searching for an answer before posting. I am looking for what all I need hardware wise to use a Rasberry pi 4 as an octoprint server. I see numerous posts on how to make the older Rasberry Pi's work, but none on the new ones. Everyone seems to do such a great job with instructions and build blogs I feel like I am just missing something.
How does the Rasberry Pi 4 connect to the Prusa i3 Mk3S? I am comfortable soldering a pinout on to a Rasberry but it looks like it comes with a pinout already which would not be correct for the Prusa. Does it connect via USB? I see some people are powering via USB external from the printer, is that still required? My printer shipped today so I am trying to get ahead and have the Rasberry Pi built before the printer gets here.
Opublikowany : 19/10/2020 3:52 pm
Romio
(@romio)
RE: Rasberry Pi 4
Hi wminear,
I didn't know that there were different instructions for using a Raspberry 4 than the Raspberry 3 with a prusa. The 4 has the same USB connection as the 3 so connecting shouldn't be a problem.
I'm in a long print now, so i can't test it right now.
Opublikowany : 19/10/2020 4:23 pm
RE: Rasberry Pi 4
I connect mine thought the header pins or USB depending on the printer.
Opublikowany : 19/10/2020 4:32 pm
RE: Rasberry Pi 4
I use the simple USB cable ... and ignored trying to make the pi a monolithic part of the printer. This way if the printer breaks, I know it is the printer.
The Pi4 requires more power than I'd be comfortable sucking from the Einsy USB.
ps: YSB -USB - SST .. hey typing was never my strong suit.
This post was modified 6 years temu 2 times by --
Opublikowany : 19/10/2020 4:39 pm
1 ludzie polubili
Andi G.
(@andi-g)
RE: Rasberry Pi 4
The Pi4 need about 3A Current  to work.... to connect it like Pi3 or Zero won‘t work. I‘m about to connect it to the PSU with a Step-Down-Module, but not sure if it works 🤷🏼‍♂️
Opublikowany : 24/11/2020 8:03 pm
RE: Rasberry Pi 4
I have had decent success connecting it for power off the Rambo pins.
Opublikowany : 24/11/2020 8:08 pm
Andi G.
(@andi-g)
RE: Rasberry Pi 4
@cwbullet
should take the firs 2 pins? (+- +-) PSU or the second one? Thank‘s for your very fast answer 👍🏻
Opublikowany : 24/11/2020 8:22 pm
egar
 egar
(@egar)
RE: Rasberry Pi 4
@andi-g
Marius Hornberger has a video on YouTube where is sets up a Raspberry Pi with a stepdown converter.  Seems very doable.
Opublikowany : 24/11/2020 8:29 pm
RE: Rasberry Pi 4
@andi-g
This cable is what I have used.
Opublikowany : 24/11/2020 11:33 pm
Andi G.
(@andi-g)
RE: Rasberry Pi 4
Thanks guys! 👍 gonna make it this weekend an be happy printing 🤓
Opublikowany : 25/11/2020 5:18 am
