proper bond tech pfte tube length
goonygoogoo
(@goonygoogoo)
having issues with filament jam, have a 41 mm pfte tube used and still getting material jam. bond tech upgraded extruder, stock head,  .6 mm nozzle.  esun dragon red fillament
Postato : 12/09/2020 2:44 pm
Utenti
RE: proper bond tech pfte tube length
Posted by: @brianofbacon
What filament?  Where is the jam?
Postato : 26/09/2020 10:49 am
MaroonOut09
(@maroonout09)
According to Bondtech's website, the length of the PTFE tube should be the same as for the stock extruder.
If the PTFE Tube you took from your MK2.5S / MK3S is still good, you can use it and keep the one we send as a spare.
If you need to cut a new one, their instructions are:
While inserted, cut the PTFE Tube at 6,30mm from the Hotend's metal face.
They also have a cutting fixture you can download a print at the link below which helps you cut the PTFE tube to the correct length.
03. Prusa i3 MK2.5S / MK3S Upgrade Kit - Installation
Did you update your firmware after you installed the Bondtech extruder using the firmware from their site:
Bondtech Firmware Variation Updates For Prusa 3D Printers
Postato : 01/10/2020 10:46 pm
