Prints fail from Octo print fine from SD card
LumixZs200
(@lumixzs200)
I have been using my MK3S+ with Octoprint for several years now and have never had an issue. I started getting issues connecting so i replaced the SD card with a new one and a fresh build of Octoprint. Now I can't seem to get a successful print through Octoprint. Same g-code prints great from SD card.
I am at a loss as to what could be causing this. New USB cable maybe? Could my RPi4b be going bad? I have an MKS4 kit on order but need ot get this one working in the meantime. Is it worthwhile to run a longer USB cable straight to my PC and try PrusaConnect? I use Octoanywhere with Octopod and have come to really like that remote access.
I am open to any and all suggestions.
Opublikowany : 19/04/2023 3:04 am
3DesignsCH
(@3designsch)
RE: Prints fail from Octo print fine from SD card
My first try would be a new USB cable. I know it doesn't sound logical, but USB cables fail quite often. 🙂
Opublikowany : 19/04/2023 6:32 am
JimB
 JimB
(@jimb)
Did you add any new Octoprint plugins recently?
Opublikowany : 19/04/2023 12:44 pm
LumixZs200
(@lumixzs200)
Thanks for the help. I removed all of my plugins except TP Link and swapped out the USB cable. So far it is working great. From here I will need to evaluate what plugins I really “must” have and try them one by one. Looking forward to my MK4 and eventually my XL.
This post was modified 3 years temu by LumixZs200
Opublikowany : 19/04/2023 1:20 pm
