Power Panic wiring? (Extending power cables)
I'm building the "official" Prusa enclosure and the PSU wires aren't long enough so I'm replacing them. While putting it back together I noticed a wire I must have overlooked. In the attached photo it is the unterminated red wire going to the +24 terminal of the Power Panic board's 24 & GND solder connections.
I *assume* this was simply attached under one of the PSU +24 lugs and I didn't notice when disassembling. Correct?
Secondly, there is no GND wire attached to the 24/GND GND. Am I correct in assuming the Power Panic board is supposed to get its DC low reference via the ground from the fault wires (white/black)?
Napsal : 02/07/2018 9:16 pm
Re: Power Panic wiring? (Extending power cables)
Hello
The red wire must be connected to +24V on the PSU. Yes, GND is from black and white cable.
Napsal : 06/07/2018 10:43 am
Topic starter
answered:
A belated thank you!
Napsal : 07/07/2018 1:45 am
