Possible to get support that's easier to remove.
Martinwill
(@martinwill)
The standard support works very fine, but are also hard to remove.
I saw a Flash Forge finder with much easier to remove support.  Especially  the connection between model en support is very easy to break.
I can't fund out how to change the support parameters.
Napsal : 12/02/2020 3:36 pm
RE: Possible to get support that's easier to remove.
The default contact distance for support in Prusa Slicer is set to 0.1mm for some reason which is too close.  Its even labelled as soluble in the drop down.  You need to change it to 0.2 or 0.25 which makes it MUCH easier to remove.
Napsal : 12/02/2020 4:07 pm
2 lidem se líbí
