Porifi3D Motors to solve the VFA problem?
Ben SreR sf
(@ben-srer-sf)
Hey,
I am quite annoyed with the VFA problem on my new Prusa Mk3s+ and trying to solve it so far without luck. I tried Extruder Linearity Correction and a experimental Idler door by Mehaidesigns.
Porifi3D claims to have a solution, but 100€ for motors is a lot. Have anyone tried them yet and can tell if they really work?
https://prorifi3d.com/collections/upgrade-kit/products/kit?variant=41879317610687
Posted : 24/09/2022 9:45 am
Ben SreR sf
(@ben-srer-sf)
RE: Porifi3D Motors to solve the VFA problem?
Or also if anyone could fix this problem in some other way it would be super interesting of course
Posted : 24/09/2022 10:55 am
rc83726282
(@rc83726282)
Thinking about pulling the trigger.  Moons motors are expensive to get here, and even just an extruder motor would be pricey.  The pack from these guys isn't that much more expensive for me so I may just do it.  If I do I'll let you know.
Posted : 15/10/2022 12:39 pm
Ben SreR sf
(@ben-srer-sf)
Yes would be definitely great to know, if you buy them
Posted : 15/10/2022 12:45 pm
rc83726282
(@rc83726282)
Hey - I was able to find that the Moons 1.8 motor can be shipped to me after all.  I'm going to buy one for the Extruder, as from the Mega-thread it's stated that the extruder gives a bigger bang for buck for VFA reduction by using the Moons 1.8.
I'll try that first, and then based on that, see about Prorifi.  They're... not cheap.
Posted : 21/10/2022 8:00 pm
Łukasz
(@lukasz-5)
Hi! I recently replaced stock Prusa motors with Prorifi3D kit on my MK3s, and I can see an improvement. I've only have one test print - 3D Benchy printed with the same gcode before and after the change. Here are some photos I've took:
Posted : 15/01/2023 9:02 pm
Ben SreR sf
(@ben-srer-sf)
Thank you a lot for sharing!
I cant tell any FVA on the Porifi Version.
I will experiment a little further, when I have time, I thought about to add a super little fuzzy skin to stop the motors do the same and get a little randomization.
But your comment makes me think about actually buying them.
Posted : 17/01/2023 12:33 am
Ben SreR sf
(@ben-srer-sf)
Just noticed I wrote it wrong the whole time. It is: Prorifi3d not Porifi3d
Posted : 17/01/2023 12:43 am
Ben SreR sf
(@ben-srer-sf)
One more thing, did you also experienced less noise from the printer? Would be interested in that
Posted : 17/01/2023 12:49 am
Łukasz
(@lukasz-5)
Posted by: @ben-srer-sf
I'm not sure if it's quieter or not. I would say that my printer was quiet with the stock motors already and it's quiet still after the change.
Posted : 17/01/2023 10:01 am
Łukasz
(@lukasz-5)
Yeah, I'm especially impressed with the improvement on the cabin roof visible in the second photo.
If you are considering buying the motors, keep in mind that only the VFA issue is improved. It doesn't help with ringing or stringing :).
Posted : 17/01/2023 10:10 am
