Pi4 direct connect to Einsy Undervolt?
p0lar
(@p0lar)
I followed the diagrams and connected the Pi4 to the Einsy and now I get undervolt warnings and throttled warnings.  do I need a separate power supply for the pi4?  should I power it via the USB-C and disconnect the 5v in from the Einsy?   add a capacitor?
Thoughts?
Napsal : 25/04/2020 4:47 pm
RE: Pi4 direct connect to Einsy Undervolt?
The Pi4 draws a hell of a lot more power than I'd want to suck off the Einsy. Definitely use a separate power supply.
Napsal : 25/04/2020 4:54 pm
p0lar
(@p0lar)
and remove the power cables from the einsy?
Napsal : 25/04/2020 5:04 pm
nilok
(@nilok)
Separate USB-C power supply for the Pi immediately.  Remove the +5V power connection between the pi and the Einsy, and leave the ground connection if you want to use GPIO TX/RX ......or remove it all and plug in the USB cable.
Is your printer grinding? Bearings squeaking? Motors smoking?
Step 1) Wash your Steel Sheet
Step 2) Return to Step 1
Napsal : 25/04/2020 5:22 pm
