Phaetus dragonfly hotend
Do you remove the collect clip before installing it doesn't appear that the hotend will fit with the clip without modification?
Clip
Mine has the clip installed but I can remember having to finagle it to it in. I have to disassemble the printer tonight so I will tell you how i got ti to fit.
RE: Phaetus dragonfly hotend
Not necro-posting, just adding in case someone stumbles onto this. I used the clip but cut the shoulder off so that it didn't interfere with the two halves of the extruder body. The height of the black portion didn't interfere and everything lined up.
(same as above for not wanting to revive a dead thread but it's one of the first searches coming up)
I am successfully using it without the clip, bot PLA and PETG (though the higher temp is limiting with the current 230, 40W heater cartridge).
