Octoprint Wifi Problems
Luna.
(@luna)
I got a raspberry pi zero w to connect to my mk 3. I followed the instructions on the website but it is not connecting to the network. Now I have it connected to the printer with USB so that i can access the ports and connect it to a monitor. I typed "ifconfig wlan0" into the terminal and the first line says"wlan0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500". From what i have seen online it seems like is should show the ip. Could someone tell me what might be happening and how I might be able to fix it?
Opublikowany : 15/12/2018 1:57 am
K7ZPJ
(@k7zpj)
Re: Octoprint Wifi Problems
From your description of the problem it sounds like you don't have the octopi-wpa-supplicant.txt file setup correctly.
The Octopi Wifi Setup and troubleshooting page explains how to check it and set it up.
Here is the link: https://discourse.octoprint.org/t/wifi-setup-and-troubleshooting/184
Opublikowany : 15/12/2018 4:11 am
