Octoprint Stats
Adrian
(@adrian)
Octoprint Stats
I've got the print history plugin installed on my Octopi, and from that I can work out how much filament I've used, and how long the printer has run, but I have to export the records as a CSV file then total the numbers up myself.  What I'd like to be able to do is to run a script on the Octopi which gives me the running total of filament used and/or the running total of print time.  I'm not bothered about splitting it down by filament type or drum.  Has anyone done this ?
Thanks
Adrian
Publié : 04/10/2020 10:48 am
RE: Octoprint Stats
Posted by: @prus-52
Thanks
Adrian
I have no experience with the plugin and unfortunately I can't help you with it.
I work with the plugin "Filament Manager". With it you have a pretty good overview of the consumption and you can also store the data in a database.
https://plugins.octoprint.org/plugins/filamentmanager/
Publié : 04/10/2020 12:32 pm
Adrian
(@adrian)
RE: Octoprint Stats
@karl-herbert
Thanks for the quick reply.
That looks as though it does a similar job to the plugin that I'm using.  What I want to be able to do is to access the database from the command line, rather than from the web interface.  The Printhistoryjob plugin has a file called printhistoryjob.db, but this isn't in a format which is readily readable.
Adrian
Publié : 04/10/2020 1:15 pm
Membre
RE: Octoprint Stats
Both Filament Manager and Print History were Abandoned.   People are working on replacements.
Publié : 04/10/2020 2:52 pm
Adrian
(@adrian)
RE: Octoprint Stats
Posted by: @charles-h13
Interesting.  Printjobhistory was only installed a few months back.
Adrian
Publié : 04/10/2020 3:03 pm
Membre
RE: Octoprint Stats
@prus-52
I missed the print "job" history.  It is one of the plugins that is jockeying to replace Print History.
Publié : 04/10/2020 3:05 pm
RE: Octoprint Stats
I am working with an older octoprint version on which the filament manager still runs, as well as the plugin PrusaMeshMap. The system is running stable and for this reason I stopped Octoprint and Systemupdates and stay with this version (1.3.10). So the system is frozen and secured in a stable state. The problem is often that after an update some plugins don't work properly anymore and you have to look for alternatives.
I will take care not to change a running system 👍
Publié : 04/10/2020 5:25 pm
