octoprint plugins
Hello
(@hello)
octoprint plugins
Hi there so im getting octoprint installed with raspberry zero w is it worth buying a webcam if so does it have auto fail detect.
and any other plugins you recomend please let me know many thanks
Respondido : 10/04/2023 1:23 am
gkas
 gkas
(@gkas)
RE: octoprint plugins
Some of my favorites are:
Backup & Restore
Camera Settings
Detailed Progress (excellent)
DetailedLayerProgress
Firmware Check
Firmware Updater
Fullscreen Plugin (Open webcam in fullscreen mode)
Octoprint is great...
Respondido : 10/04/2023 5:16 am
Hello
(@hello)
Thanks for your input may I ask what board your running it on
Posted by: @gkas
Backup & Restore
Camera Settings
Firmware Check
Firmware Updater
Respondido : 10/04/2023 5:32 am
gkas
 gkas
(@gkas)
Pi 4 B 8GB.... I've had it a while 😀
Respondido : 10/04/2023 5:35 am
Hello
(@hello)
unfourntly all i can affors is the zero so my plugins are limited if you could please rate best to least needed i would much apreciate it
Posted by: @gkas
Respondido : 10/04/2023 5:58 am
gkas
 gkas
(@gkas)
Backup & Restore
Firmware Check
Firmware Updater
Respondido : 10/04/2023 6:00 am
Hello
(@hello)
thanks very much
Posted by: @gkas
Backup & Restore
Firmware Check
Firmware Updater
Respondido : 10/04/2023 6:05 am
JimB
 JimB
(@jimb)
Since you said you have a Raspberry Pi Zero W (not Zero 2 W), I would not do too much in the way of plugins: a stock octoprint and printing will be pushing it near its limit.
Respondido : 10/04/2023 2:20 pm
_rob_
(@_rob_)
Posted by: @hello
You could use the pi zero to bridge the serial interface over wifi, run octoprint with all the plugins you want on another computer on your network, and connect it to the printer's ip address using the Network-Printing Plugin. That's how I do it.
Respondido : 10/04/2023 11:19 pm
Hello
(@hello)
Posted by: @_rob_
Posted by: @hello
Thanks sounds confusing but I will look into it
Respondido : 11/04/2023 8:57 am
_rob_
(@_rob_)
Posted by: @hello
It's pretty simple. Just install socat and run
socat TCP-LISTEN:12345,reuseaddr file:/dev/ttyAMA0,nonblock,waitlock=/var/run/ttyAMA0.lock
Make it a systemd service so it runs on startup...
[Unit]
Description=USB Serial Bridge for MK3 Printer
After=network-online.target
Wants=network-online.target
[Service]
Type=simple
ExecStart=socat TCP-LISTEN:12345,reuseaddr file:/dev/ttyAMA0,nonblock,waitlock=/var/run/ttyAMA0.lock
Restart=always
[Install]
WantedBy=multi-user.target
Respondido : 11/04/2023 9:49 am
