Octoprint plugin Pushover notification if filament runs out
Hubsi
(@hubsi)
Hi guys,
could somebody help me with the pushover plugin. It works perfect in case of a failure and startup of octoprint, if temps are reached...
But I cannot make it working with the filament runout, which I mainly want to have.
I have a Prusa MK3S and running Octoprint on a RaspPi 3B.
In several threats I found that there were discussion if the plugin supports M600 or not. Or to use M226 instead. But did not really find a solution to make it working. I know that my Prusa sends the M600 in case of an empty filament. But this does not trigger the plugin. M600 does not give a real pause I guess.
Is there a way to do so in the Gcode scripts section of Octoprint or should I add something into prusa slicer to trigger an additional pause.
Or any other solution for that?
I just want to have a push notification if the filament is empty.
Many thanks
Martin
Postato : 17/04/2020 9:57 am
gkas
 gkas
(@gkas)
RE: Octoprint plugin Pushover notification if filament runs out
I've been looking at the same thing.  I would like the M600 for a color change. I haven't found a solution.
Postato : 17/04/2020 3:47 pm
Hubsi
(@hubsi)
I found something in the Octoprint forum but I am no coder and do not know which script to use for pushover. But that could be a way in the right direction
https://community.octoprint.org/t/m600-event-hook-request/4126/2
Best Martin
Postato : 18/04/2020 7:04 am
Hubsi
(@hubsi)
I now found the plugin Octoslack which could handle the M600 commands.
Filament runout works fine with that
Best
Postato : 20/04/2020 8:50 am
