OctoPrint on MK3?
Page 7 / 7
lignumaqua
(@lignumaqua)
Re: OctoPrint on MK3?
Agreed. I've now done both, disabled BT and moved the port we are using over to the faster hardware UART. Added the following overlays to /boot/config.txt on the Pi Zero W
dtoverlay=pi3-miniuart-bt
dtoverlay=pi3-disable-bt
I've also changed the port to serial0, which in Stretch and later versions of Jessie should always work no matter how the ports are configured internally.
Posted : 16/12/2017 11:58 pm
Jeff
 Jeff
(@jeff-5)
Yes, exact same issue with OctoPrint, stops after purge line. I think that yulong.1 has it right, it's the if/else statement in the Gcode which is causing the problem. FWIW Repetier-Server has no problem with it.
That did the trick for me too, thanks lignumaqua! Time to take things apart and solder some headers 🙂
Posted : 17/12/2017 3:41 pm
lignumaqua
(@lignumaqua)
If anyone is following along. Not unexpectedly using my own unreleased build of the current state of GitHub did have some issues. In particular the serial link was seeing a lot of errors and re-sends. This caused the print head to sporadically jump to 0,0 and print in mid-air.
Not sure if this was a Pi issue, an Einsy issue, or something else. Best way to find out is to curb my impatience and wait for a true tested release from Prusa. 😆 For now I've reverted to release B122 and an external Pi connected through the USB port. All is happy again and I've satiated my curiosity that an internal Pi Zero W will do the job in the future. 🙂
Posted : 17/12/2017 4:14 pm
Jan Pichrt
(@jan-pichrt)
New firmware release is UP! Awesome... https://www.prusa3d.com/downloads/firmware/prusa3d_fw_3_1_1_rc2_b137.zip
/edit: but this fw not working with Rpi too 🙁
/edit2: working! just dont forgot to enable 2nd uart in menu 😉
Posted : 17/12/2017 10:44 pm
lignumaqua
(@lignumaqua)
Yep, new release seems to be working well. Or, it would be, if I hadn't just had a bearing fail and seize up! 🙁
Not good that a linear bearing fails in a week. (It was one of the Y axis ones, and one of the others is on its way) Looks like I might have to try and find a better quality than Prusa uses and swap them all out. Is this a known problem with Prusa printers?
Posted : 18/12/2017 9:21 am
Mike C
(@mike-c-3)
Curious if you are using Octopi or Octoprint installed on Raspbian? I am unable to connect to Serial port:
Started to get this after disabling BT
Connecting to: /dev/ttyAMA0
Changing monitoring state from 'Offline' to 'Error: Connection error, see Terminal tab'
Unexpected error while connecting to serial port: /dev/ttyAMA0 OSError: '[Errno 13] Permission denied: '/dev/ttyAMA0'' @ comm.py:_openSerial:1931 (hook default)
Posted : 20/12/2017 11:24 pm
Page 7 / 7
