Octoprint freezes printer on staetup
Hello
(@hello)
 when octoprint try's to connect it reboots printer but gets stuck on the screen when you first turn printer on with fan blasting full what do I do I've got dash board an ui customizer installed. it works fine when it goes into safe mode where it disables all plugins any help is much appreciate I am on prusalink currently but want to go back to octoprint
Napsal : 26/06/2023 8:47 am
Walter Layher
(@walter-layher)
RE: Octoprint freezes printer on staetup
Do you turn on the Raspberry Pi and the printer at the same time (e.g. via a switch or relais) or one after the other? If yes, in which order? I have both connected to a relais with Tasmota and switch them on with it. When OctoPrint is ready it is connected to the printer and everything is normal. I also have Dashboard an some other plugins installed. I don't have UI Customizer but OctoPrint-Widescreen. If I turn off the printer alone for some reason and switch it back on there can be problems with re-connecting it to OctoPrint. In that case I shut down OctoPrint and switch the relais off and on again.
Napsal : 26/06/2023 9:07 am
Hello
(@hello)
I do first pi then printer about 3 seconds after
Napsal : 26/06/2023 9:09 am
Hello
(@hello)
The pi won't even of read the image within that time
Napsal : 26/06/2023 9:15 am
Walter Layher
(@walter-layher)
Yes, I think this delay is no problem. On my MK3S+ I can see that the screen with the boot message "Prusa Research something something" appears again after the Pi has booted but then the normal status screen appears. It does not get stuck. Did you try to use another USB socket on the Pi? I have mine connected to one of the USB3 sockets, although I think USB2 should also be enough for this. Did you look into the log file to see what happens when it tries to connect?
Napsal : 26/06/2023 9:30 am
Hello
(@hello)
Log file showed connecting until I cancelled it I'm using raspberry zero via USB I know but I don't want to connect via gpio
Napsal : 26/06/2023 9:33 am
Walter Layher
(@walter-layher)
Zero is not recommended because of single core. Dashboard and/or other plugins are perhaps too much for the Zero.
Napsal : 26/06/2023 9:38 am
Hello
(@hello)
It does it without plugins
Napsal : 26/06/2023 9:39 am
Walter Layher
(@walter-layher)
Yes, the plugins are too much. I would try to find at least a Pi3 for this. I think these are easier to get than a Pi Zero2.
Napsal : 26/06/2023 9:44 am
Hello
(@hello)
Sorry for late reply had to go somewhere it does it without plugins Installed and you caRnt get anything other then pi zero
Napsal : 26/06/2023 7:01 pm
Walter Layher
(@walter-layher)
But it looks like the end of the shortage is approaching (slowly) ...
Napsal : 26/06/2023 7:08 pm
Hello
(@hello)
Yeah never used to be able to get zero now you can
Napsal : 26/06/2023 7:09 pm
Walter Layher
(@walter-layher)
The prices for the other models also are going down a bit and more are actually available. But a Pi3 is still half the price of a Zero 2 W, which is about on the same level as a Pi4 4GB on the big river site.
Napsal : 26/06/2023 7:15 pm
Hello
(@hello)
Where are you seeing pi3 half price of a zero2
Napsal : 26/06/2023 7:16 pm
Hello
(@hello)
Here a zero 2 is 50$ that's new Zealand dollars and a pi3 there was 1 site last week that sold one for 300 dollar and now you caRnt even get them
Napsal : 26/06/2023 7:18 pm
Walter Layher
(@walter-layher)
Well the markets seem to be different at the moment. I checked on German A*** and Zero 2 W were at about 130 Euros, Pi3 b (not +) at about 54 Euros.
Napsal : 26/06/2023 7:23 pm
Hello
(@hello)
54 euros is normal price isn't it I may have to look and see if they ship here
Napsal : 26/06/2023 7:25 pm
Walter Layher
(@walter-layher)
It is the "official price" of an official German reseller (Berrybase) for a Pi 4 2GB, which is still out of stock at the moment. They currently only have Zeros at prices more or less the level before the shortage. But availability on A*** at still scalper prices is getting noticeably better so we can probably expect that official resellers will get more stock in the near future.
Napsal : 26/06/2023 7:40 pm
Hello
(@hello)
Hopefully I guess I'll stick with prusalink
Napsal : 26/06/2023 8:00 pm
