Octoprint Bed Visualizer G-Code
chris.b47
(@chris-b47)
Hello,
I am fairly new to octoprint and have installed several recommended plug-ins. Once of them being the Bed Visualizer.
What lines of g-code need to be input into the "g-code command" box?
I have also heard there is a Prusa Mesh Visualizer however I am not quite sure how to go about installing it/setting it up on my RPi 3B+...
https://github.com/PrusaOwners/OctoPrint-PrusaMeshMap
Any help is appreciated.
Respondido : 22/10/2018 9:38 am
Dutchy
(@dutchy)
Re: Octoprint Bed Visualizer G-Code
I tried installing this on the Pi0 but can't get it to work.
Respondido : 22/10/2018 11:30 am
andy.b15
(@andy-b15)
If you go into Settings > Plugins there should be an option to install a new plugin and choose from URL. Then paste this URL in: https://github.com/PrusaOwners/OctoPrint-PrusaMeshMap/archive/master.zip
One warning, it takes a long time to install (30-45 minutes) and during this time it will look like it isn't doing anything. Just let it go and it will let you know when it is finished.
Respondido : 22/10/2018 1:31 pm
chris.b47
(@chris-b47)
Do I have to manually install matplotlib and numpy beforehand, or does the link install them as well?
Thanks!
Respondido : 22/10/2018 3:21 pm
Dutchy
(@dutchy)
Thanks!
Install worked for me now,
tested, image only refreshes after changing color in the settings.
Got 0.32 ~-.032 @ 70c total bed variance 0.595mm I don't know if that's good or not.
And @ 85c 0.691 Front right is the high point.
Might sand the stand a bit.
Respondido : 22/10/2018 3:38 pm
chris.b47
(@chris-b47)
I installed the plugin, but it is not outputting the heatmap image.
It runs the g-code, but does not show an image once it is finished (even after clicking reload heatmap image)
Respondido : 22/10/2018 7:52 pm
The Plastic Shed
(@the-plastic-shed)
Nope it doesn't in some browsers - Firefox / Waterfox in particular, if you come out of it and then open it again your map will appear as if by magic. This issue doesn't exist in IE (Internet Explorer). I have no other browsers loaded.
If you are using NoScript, Adblock, or UBlock you need to whitelist your octoprint instance.
Respondido : 22/10/2018 11:44 pm
Dutchy
(@dutchy)
I'm using Chrome and that doesn't refresh either.
Respondido : 23/10/2018 3:37 pm
Mr Moo
(@mr-moo)
@chris.b47
What was the gcode you used please?
Respondido : 18/02/2019 6:44 pm
spiff72
(@spiff72)
RE: Octoprint Bed Visualizer G-Code
I see this is an older post, but I have both "Bed Visualizer" and "Prusa Mesh Level" installed, and I used the following for the Gcode on my MK3S:
Bed Visualizer:
G80
@BEDLEVELVISUALIZER
G81
Prusa Mesh Level (didn't change - used default):
G80 ; mesh bed leveling
G81 ; check mesh leveling results
I also had to add my Octoprint IP to the whitelist in uBlock Origin to get the heatmap to load for the Prusa Mesh Level to load the image (as mentioned by another post above).
Respondido : 26/07/2019 10:28 pm
4 les gusta
Kisho
(@kisho)
@spiff72
I know this almost two years old, but I wanted to say a HUGE thank you. I am not that familiar with machine code and had a very difficult time making the Bed Visualizer actually return the results until I found this post. Huge thanks!
Respondido : 17/02/2021 4:39 am
1 les gusta
HermannSW
(@hermannsw)
Posted by: @andy-b15
I tried to install that on a Pi3A+ (my OctoPrint Pi), and that has only 512MB RAM.
First there were many of these messages:
Building wheel for numpy (PEP 517): still running...
Finally the Pi did hang up, was pingable but ssh into did not work.
After power cycling no PrusaMeshMap plugin was installed.
I did install "Bed Visualizer" plugin before from Plugin Repository, and that works.
There was gcode to copy, for "Prusa Firmware" and "Prusa Mini".
Since I have a Prusa MINI+, I chose the latter option:
https://github.com/jneilliii/OctoPrint-BedLevelVisualizer/blob/master/wiki/gcode-examples.md#prusa-mini
MINI+ did a bed leveling, and then showed below map.
Not sure what the map will tell me, though.
Are the reported min and max values in millimeter unit?
Is 0.531 difference between min and max good/bad?
Respondido : 23/02/2022 3:26 pm
3DPrintard
(@3dprintard)
Miembro
Here are some settings that work well for the Prusa MK4
Esta publicación ha sido modificada el hace 3 years por 3DPrintard
Respondido : 25/06/2023 7:16 pm
