Octopi setup in Slicer
Agkirk
(@agkirk)
Where is the Octopi communaction menu/page in the latest issue of the Prusa Slicer?
Respondido : 04/02/2021 12:08 am
Lize
 Lize
(@lize)
RE: Octopi setup in Slicer
Do you mean Printer Settings->General:
Esta publicación ha sido modificada el hace 5 years por Lize
Respondido : 04/02/2021 3:14 am
towlerg
(@towlerg)
Be aware of the changes to the way printers are defined in 2.3.0. Note that the API key is moved to a physical printer definition, that setting being shared by any number of virtual printers. See attached, One physical printer is associated with 3 user presets.
Respondido : 04/02/2021 10:50 am
Just in case it's not obvious (it wasn't to me), click the little gear icon in Printer Settings to access the physical printer settings.
Respondido : 04/02/2021 3:22 pm
Agkirk
(@agkirk)
I needed all the tips!  I am back in business.
Thanks
Respondido : 04/02/2021 5:12 pm
NickT_in_SD
(@nickt_in_sd)
Is it possible to print from PrusaSlicer using a Raspberry Pi 4? I have OctoPrint setup and the web interface is working. I thought I had read you could only do it through Prusa's software for Pi Zero installations.
Respondido : 18/02/2021 6:58 pm
towlerg
(@towlerg)
It dos not matter what hardware OctoPrint is running on. PrusaSlicer sends to an API key or IP address.
Respondido : 18/02/2021 7:08 pm
