Octopi setup in Slicer
Where is the Octopi communaction menu/page in the latest issue of the Prusa Slicer?
RE: Octopi setup in Slicer
Do you mean Printer Settings->General:
Be aware of the changes to the way printers are defined in 2.3.0. Note that the API key is moved to a physical printer definition, that setting being shared by any number of virtual printers. See attached, One physical printer is associated with 3 user presets.
Just in case it's not obvious (it wasn't to me), click the little gear icon in Printer Settings to access the physical printer settings.
I needed all the tips! I am back in business.
Thanks
Is it possible to print from PrusaSlicer using a Raspberry Pi 4? I have OctoPrint setup and the web interface is working. I thought I had read you could only do it through Prusa's software for Pi Zero installations.
It dos not matter what hardware OctoPrint is running on. PrusaSlicer sends to an API key or IP address.
