Octolapse - confused with settings - G90 or G91 which one I have to use?
I finally get hands on RPi3 and I used it to install Octopi and Octolapse, after settings (connected via USB) I tried to run octolapse, but the result is messy, I noticed error:
"XYZ movement was detected, but the axis mode has not been set. Please add a G90 or G91 to the top of your start gcode. "
Which axis mode I should use on my MK3? (I am using Slic3r Prusa edition, and dont know what exactly to do).
Opublikowany : 06/05/2019 7:48 pm
RE: Octolapse - confused with settings - G90 or G91 which one I have to use?
I found that if I just want to use the mode where it moves the extruder to a fixed position after each layer and takes a picture, this error doesn't matter.
Opublikowany : 07/05/2019 10:56 am
