Nylock + Prusa Leveling Guide variation problem
Hi, I just upgrade my prusa mk3s to mk3s+ with the official prusa kit and at the same time I install the nylock mod.
I have a pi with octoprint and the plugin : prusa leveling guide.
the problem is I am never able to go lower than 0.1 variation because even if I dont touch the screw the result are never the same. If I run 2 calibration back to back the result varies a lot between them anyone have a idea of what I can do ?
Thanks
RE: Nylock + Prusa Leveling Guide variation problem
I would have recommended you not upgrade two things at once. It makes it hard to know which upgrade is causing you problems. I would post the question in the Nylock Mod thread. It might get you more responses than a new thread.
Thanks
Why did you install the Nylock mod? Where do you get instructions on how to make use of it? Who designed it and why aren't they able to help?
@tim-2
Hence why I posted that above.
I would go to the thread and post a question. They either will help you or I would recommend reverting to the MK3S+ without the mod.
