Nozzle profiles 0.3; 0.35; 0.5 and 0.8 ?
JulesC46000
(@julesc46000)
Hi everyone, does anyone have the correct profiles on prusaslicer for prusa MK3s of nozzles 0.3; 0.35; 0.5 and 0.8 mm ?
Posted : 06/11/2020 9:57 pm
RE: Nozzle profiles 0.3; 0.35; 0.5 and 0.8 ?
I've got a set of sample profiles here that should get you started. If you're running PrusaSlicer 2.3x, you'll have to convert the printer profiles to physical profiles.
Posted : 07/11/2020 12:34 am
Retsam
(@retsam)
Profiles indeed can be imported to Prusa Slicer (2.4.2), but filament cannot be selected / imported, hence it seems unusable.
Posted : 03/07/2022 5:35 pm
Henry
(@henry-2)
@retsam - If I understand your issue, you can select a filament then go to Dependencies. Enable Expert view. You should see "Compatible printers condition". Edi tit so that there isn't a nozzle restriction on it. You may end up needing to tweak the filament to work with different nozzle diameters to get great prints, but I'd expect something usable without further tweaks.
Posted : 03/07/2022 5:42 pm
Retsam
(@retsam)
@henry: good hint. I'm still struggling with Printer / Print / Filament dependencies, but possibly will sorted out tomorrow, if not today. Thank you!
Posted : 03/07/2022 8:33 pm
