My Octopi Zero setup/Einsy connection.
I am using this Raspberry Pi Zero case/mount/camera mount, but slightly modified to hold the cabling, and connector I am using.
https://www.thingiverse.com/thing:2782145/#made
I then soldered on a 90 deg 14 pin ribbon cable connector only using the needed pins. On the other end I soldered in a set of long jumper pins to attach the 14 pin ribbon cable to the Eisny board. Should be pretty sweet, and painless!
Re: My Octopi Zero setup/Einsy connection.
Nice setup, what filament did you use for all the parts?
MHC
Thanks! I like to make things as modular as I can, and make them modular in casde I want to change things up lol.
It's Polyplus PLA by Neva. It is PLA, but pretty close to Prusa Orange, and this doesn't need to be heat resistant so I figured lets go for it!
And I know there is solder in more hole than is needed for the header lol, I was a bit generous with the flux and so someof the empty holes were filled. Doens't hurt in the end 🙂
Where/how did you mount this on the printer? Can you post some photos of it installed?
My printer will arrive this week, and I will show you how I install it then! 😀
Wondering if you've gotten this set up.
