Mod heater cartridge to protect wire connection by encasing in either high temperature epoxy or silicone
EsotericMaker
(@esotericmaker)
I just needed to replace my MK3S+ heater cartridge because somehow in removing a nozzle (for the first time), I must have damaged the wires where they enter the cartridge causing them to short out.
Looking at the wire entry point, it is clear that this is a weak point since the insulation ends there and the wires are already spaced very close together.
What if I made a PLA cylindrical mold to fit around the end of the heater cartridge with say a diameter about 4mm larger than the cylinder and extending out say 10mm. I could then fill the cavity either with:
  • High temperature epoxy - more ridgid and maybe more protective
  • High temperature silicone - more flexible but maybe less protective though would still offer some strain relief and insulation between the wire ends - also might help protect against "blobs" (or at least they could be sacrificial)
JB Weld High Heat is borderline as it is rated up to 550 deg F (287 deg C) and is not conductive (unlike the Extreme Heat version) - I assume that the cartridge must get a little hotter than the heatblock so when printing things like PC blend at 270, you may be around 287 on the cartridge...
Any thoughts?
Postato : 01/02/2023 6:49 pm
Hello
(@hello)
RE: Mod heater cartridge to protect wire connection by encasing in either high temperature epoxy or silicone
Sounds good but may want to print in a stronger material
Postato : 01/02/2023 6:52 pm
Hello
(@hello)
I was thinking heat shrink around wires
Postato : 01/02/2023 6:53 pm
EsotericMaker
(@esotericmaker)
The PLA would just be for a mold and since it has such a low melting point (while by definition the epoxy/silicone and heater cartridge tolerate much hotter temperatures), it should be very easy to release the mold from the epoxy by just melting/softening it
Postato : 01/02/2023 6:55 pm
Hello
(@hello)
Oh yes good idea
Postato : 01/02/2023 6:58 pm
EsotericMaker
(@esotericmaker)
Thought of that but:
Shrink temperature of FEP is 177°C (350°F) Melt Temperature of FEP is 275°C to 295°C (525°F to 563°F)
Even the so-called high heat shrink tubing on Amazon cites a maximum working temperate of 250 F (not centigrade)
Postato : 01/02/2023 6:59 pm
Posted by: @esotericmaker
I agree. However, to be on the safe side, I would use high-temperature silicone as filling material (up to 600 degrees C.).
wbr,
Karl
Postato : 01/02/2023 7:13 pm
EsotericMaker
(@esotericmaker)
Meanwhile as a temporary measure, I put a (careful) dab of high temperature RTV silicone where the wires join the heater cartridge. At a minimum, it will provide some electrical insulation so that I don't inadvertently short out the terminals when changing a nozzle.
At best, it will provide a (little) extra support and strain relief as well as preventing the wires from touching if/when the insulation pulls back a little from the cartridge.
Can't see any downside to this...
Postato : 01/02/2023 10:34 pm
Netpackrat hanno apprezzato
rdpeder59
(@rdpeder59)
How did this work for you?  I don't like the sharp 90 degree bend that is needed to put the heater in from that side.  In addition to doing the mod you proposed, I was thinking about putting the new heater in from the other side and doing a more gradual bend after the silicone dries.
Postato : 11/07/2023 4:55 pm
EsotericMaker
(@esotericmaker)
Posted by: @rdpeder59
Worked well so far...
Postato : 11/07/2023 6:02 pm
rdpeder59
(@rdpeder59)
Thanks!  I'll proceed with silicone.
Postato : 11/07/2023 6:35 pm
