MK3S Mosquito integration
Pagina 18 / 20
Utenti
RE: MK3S Mosquito integration
@christoph-e5
They also sell a knockoff of the Mosquito.  I have a real Magnum and a Knock off regular.  They print great.  I use the socks and they also work well.  5 thumbs up.
Postato : 05/11/2019 1:23 pm
Bunny Science
(@bunny-science)
The cloned Mosquito also adds a clamped arrangement for the heater cartridge. I am not a fan of the original's loose fit, but pack the gap with boron nitride scheme. On my original Mosquito, I tighten the gap with a brass shim.
I really like the clone's clamping screw. You can still use the boron nitride as thermal compound, and gain the ability to reduce the gap.
Your clone is working well?
Postato : 05/11/2019 5:49 pm
ed
 ed
(@ed-3)
Have a link to the clone? I don’t see it on TL
Postato : 05/11/2019 6:03 pm
Bunny Science
(@bunny-science)
The one I found was not by TL, but rather "Mellow"
https://www.aliexpress.com/item/4000088018308.html
Don't know if this is the same that Charles is testing.
Postato : 05/11/2019 6:08 pm
Utenti
Posted by: @guy-k2
I have been printing with these for 4 months or so.  They work as well as the E3D in my book.
Postato : 05/11/2019 6:16 pm
ed
 ed
(@ed-3)
You mean the slice engineering correct?  Might have to give a try
Postato : 05/11/2019 7:05 pm
ACE
 ACE
(@ace-2)
@charles-h13 which thermistor do you use with the mosquito clone? Original slice or something different?
Postato : 05/11/2019 8:09 pm
Utenti
Posted by: @christoph-e5
I ordered one off AliExpress - not sure of which one.
Postato : 05/11/2019 9:21 pm
Utenti
jmone
(@jmone)
Thanks - I got a clone of the "Magnum" to compare to the original.  I'll be interested to see what the Heat Break Insulator is like as I've always broken the genuine slice one.
I'd also ordered the socks on the weekend after stumbling across them.
Postato : 05/11/2019 11:10 pm
Utenti
Bunny Science
(@bunny-science)
That leaves just an equivalent high temp thermistor to find. Not much point doing a Mosquito (clone) without also installing a thermistor that can tolerate high temps.
Those TL socks say 290C. My Permatex Copper is supposed to be good to 371C
Questo post è stato modificato 7 years fa da Bunny Science
Postato : 06/11/2019 12:52 am
Utenti
rmm200
(@rmm200)
Let us know how that heater works out. I have to say the AliExpress page looks really good...
Postato : 06/11/2019 12:54 am
Bunny Science
(@bunny-science)
Maybe this one https://www.aliexpress.com/item/4000275489841.html
😀we are posting at near same
Postato : 06/11/2019 12:59 am
Bunny Science
(@bunny-science)
BTW, you cannot solder to the leads of the Slice Engineering thermistor. I discovered that when I clipped off the connector of my original.
Had to do crimp connections. I don't recommend that unless you have good, small pin, crimping tools.
Postato : 06/11/2019 1:03 am
rmm200
(@rmm200)
JST XH connectors big enough - or need something else? I just got set up to make hundreds of those...
And what do you do with the heater cable?
Postato : 06/11/2019 2:47 am
jmone
(@jmone)
Posted by: @guy-k2
Mmmm that is almost enough to give PEEK another go....
Postato : 06/11/2019 3:03 am
Utenti
Posted by: @guy-k2
That is the one/
Postato : 06/11/2019 3:30 am
jmone
(@jmone)
Mmmm my Mosquito Magnum (sans heat shield) has started to leak somewhere around the heat break / hot block (will disassemble once the print finishes).  Has been fine for months.  Anyone else had issues?
Thanks
Nathan
Postato : 15/11/2019 4:10 am
Pagina 18 / 20
