Max Z because of enclosure - Where to enter restraints?
Robin
(@robin-2)
Hello,
I have my printer in a Tukkari case, but it is on a slab so is a littler higher than it should be.  As a result, the extruder juuuuuust touches the top when it goes to max height (Its just 1-2 mm too high and actually warps the case up slightly if it goes to max Z).
I would like to limit the max (Even for z Calibration).
Can you advise me the minimum number of places I can enter this constraint so it is effective for Prusa slicer, Octoprint, Hardware?
Thanks.
Publié : 22/09/2022 9:19 pm
Membre
RE: Max Z because of enclosure - Where to enter restraints?
I think you have to alter the firmware.  I would recommend pitting the vase on spacers to boost the internal height if that is possible.
Publié : 28/09/2022 2:54 pm
Netpackrat
(@netpackrat)
You could set a lower Max Z by modifying the firmware, but I don't think the calibration will run right if the X carriage doesn't go all the way to the top of the frame.  Maybe if you added spacers/stops of some sort to physically reduce the travel by the same amount as you do in firmware.
https://www.printables.com/@Netpackrat/models
Publié : 28/09/2022 9:37 pm
RandyM9
(@randym9)
That looks like a nice enclosure. It also looks like it sits on the tabletop with no base.
That being the case, I agree with Chuck that finding or making some sort of spacers to raise the enclosure up to the needed height is likely the simplest solution.
Cheers
Publié : 01/10/2022 4:32 am
