Looking for a single-spool drybox... What cheap ready-made containers have you found?
Stránka 2 / 2
digbat
(@digbat)
RE: Looking for a single-spool drybox... What cheap ready-made containers have you found?
I am starting to experiment with the "sistema 169 oz 5 L"  air-sealed food container. I printed the bearings and hot glued them inside the box and to the lid.
I am using it horizontally initially, but it would probably be better vertical - still into first few prints without problems so far.
Sitting on an experimental filament buffer - I don't have tiny fingers so using the MMU2S buffer is a chore - I want to be able to access and move the filament quicker.
Bearings printed quick with 0.6 and PETG (not in good condition and needing drying and put in a dry box obviously).
Cheers
Digbat
TANSTAAFL
Napsal : 16/02/2020 12:02 pm
vintagepc
(@vintagepc)
That's the same box I settled on. See my print link for a stand that keeps it vertical.
Napsal : 16/02/2020 12:06 pm
Robert Setterlund
(@robert-setterlund)
If you are in the USA and there is an ACE Hardware store near, they have 21 cup Rubbermaid food containers for under $9.00 shipped to the store.
Napsal : 21/02/2020 3:31 pm
digbat
(@digbat)
vinagepc,
Thank you for your stand idea it looks like it will do the job - I opted for a more minimal solution - small wedge hot glued opposite the lid.
Not as complete as your solution but it works well enough for me.
I have 5 boxes made so far. I am working on a solution with bags with silica gel inside to keep the filament dry for longer. The bags are intended for sink plugholes to stop debris going down the drain - cheap, small, light, constrain the beads, let air through - worth a go.
Cheers
digbat
TANSTAAFL
Napsal : 21/02/2020 4:46 pm
Stránka 2 / 2
