Linear rods vs linear rails
H20Slicer
(@h20slicer)
For those of you who have upgraded your y-axis and possibly x-axis to linear rails, have you noticed any real benefits or drawbacks to doing so?
Opublikowany : 21/01/2020 4:33 am
vintagepc
(@vintagepc)
RE: Linear rods vs linear rails
Better bearings are reported to make an appreciable difference, but I've seen numerous folks (Toms3D, a couple r/prusa3d posts) make the step to linear rails (from bearings that already performed well, be they stock or 3rd party) and report marginal or no appreciable improvement.
Personally I run vesconite bushings for the reduced noise over roller bearings; the surface finish in conjunction with 0.9 degree steppers is fantastic.
From a purely financial perspective, there are probably better upgrades you can spend your money on before linear rails for more bang-for-buck improvements.
Opublikowany : 21/01/2020 2:10 pm
1 ludzie polubili
x50arm
(@x50arm)
My linear bearings were running a little rough so I swapped them out for linear rails.  The linear rails are much smoother than my old bearings (new bearings would have been also), but I didn’t see any real change in print quality.
Opublikowany : 22/01/2020 1:15 am
@allen-m2
Yes, much smoother, and i'm using these one: https://www.igus.at/product/1195 expensive, but much more quiet than the Prusa bearings.
Opublikowany : 24/01/2020 9:11 pm
Lichtjaeger
(@lichtjaeger)
Opublikowany : 24/01/2020 10:05 pm
