Is PrusaMeshMap still a valid plugin?
AWilling
(@awilling)
I'm curious about my leveling, and so I installed the listed "Bed Visualizer" plugin in Octoprint.  Then, I noticed it needs some input in order to work properly.  In searching for that input, I found a small tutorial from 2018 on installing & using the "PrusaMeshMap" plugin.  It looks like this plugin hasn't seen any activity in 2 years.  Is it still a valid & working plugin?
If "PrusaMeshMap" is no longer functional, does anyone know of a guide for using the standard "Bed Visualizer" plugin in Octoprint?
Opublikowany : 14/11/2020 8:52 pm
Baklin
(@baklin)
RE: Is PrusaMeshMap still a valid plugin?
I don't remember doing anything extra when I installed it, but that is some time ago.
I know I had to add some g-code in the plugin setup. And it worked after that.
But I see there is a know problem with some installs posted at the bottom of this page.
Opublikowany : 15/11/2020 10:52 am
