incomplete deposition of the material
Martin Nicolas Ramos
(@martin-nicolas-ramos)
Hello, I'm trying to print a small piece that's 0.5 mm thick. The problem I'm having is that when I print, parts of the print are missing, and I get a rough surface. What things do you recommend I do?
Napsal : 11/05/2026 1:06 pm
RE: incomplete deposition of the material
i change the speed, clean the print bed, but nothing work. The piece is flat, it does not support material. The filament that i am using is PLA
Napsal : 11/05/2026 1:09 pm
0.5mm in which plane?
If you are using the default nozzle that's only one extrusion in X and Y and in Z there's only room for 2, perhaps 3 layers...
Is your print sheet scrupulously clean?
For specific advice save your project as a .3mf file
Files > Save Project as
It would also help us to see the result of the built-in first layer Z offset calibration *on the print sheet*
Napsal : 11/05/2026 2:08 pm
