IGUS Drylin
AntonioZZZ
(@antoniozzz)
IGUS Drylin
Hi there, is anyone using the IGUS Drylin bushing instead of the linear bearing? i see they are used in the pitstop carriage mod, and got curious, any of you has experience with them? would be possible to use drylin on all axes to quite off the bearing noise?
thanks in advance
Respondido : 31/08/2021 12:51 pm
Dan Rogers
(@dan-rogers)
They work well
I installed drylins on my first MK3s some time ago - only use them on the X and Y axis (6 in total).  On my second MK3S+, I built the kit and built it from the ground up with drylins replacing the linear bearings for X and Y axis.  They are somewhat finicky with regarts to how to mount them and how much squeeze to put on them (the holes through the drylin are larger than 8mm - so you have to put some squeeze on them.
Respondido : 31/08/2021 3:48 pm
AntonioZZZ
(@antoniozzz)
how do you squeeze them?
Posted by: @dan-rogers
how do you squeeze the Y? did you print some adapter? the mk3s+ come with the metal clip, is it enpugh to put the neede squeeze in the drylin? same questione about the Z, i see the printing carriage (the pitstop mod) has many screws to adapt the squeeze
thanks
Respondido : 31/08/2021 3:55 pm
Dan Rogers
(@dan-rogers)
The clips have screws that you use to adjust your bearing tension - even have to do it with the linear bearings.
Respondido : 01/09/2021 11:23 am
Dan Rogers
(@dan-rogers)
Don't put drylins on Z.
Chicago Keri
(@chicago-keri)
RE: IGUS Drylin
I had Drylins plus the special black aluminum rods for Drylin for all 3 axes on my Mk2.5s for a long time.
They worked well, but not as well as Misumi bearing on high-quality rods.
In particular,
1- they are quite tricky to mount on the Y axis, the slightest mis-alignment jams the carriage.
2- as advertised, they are self lubricating. The specially-treated aluminum rods always felt slippery.
3- they run smoothly and quietly
4- they have considerable "slop" and wear out relatively quickly, especially on the X axis.  The relatively soft aluminum rods shown no wear at all however.
5- the black rods look awesome on a black and orange Prusa!
¡no entiendo Español!
Nein! Nicht Versteh!
Я немного говорю по-русски но не очень хорошо, и...
I'm not very good at English either! Maybe someday I'll find a language I'm good at?
Respondido : 15/12/2021 12:07 am
Tim
 Tim
(@tim-5)
RE: IGUS Drylin
If you use IGUS bearings I strongly advise you to use the ones with an aluminium casing. They are drop in replacements for the stock bearings. I have shared my experience here, if your are interested:
https://www.reddit.com/r/prusa3d/comments/mh5sig/my_igus_bearing_experience_on_a_prusa_mk3s/?utm_medium=android_app&utm_source=share
Respondido : 10/01/2022 8:44 pm
1 les gusta
